Anyone have any ideas why my oem clutch started squeaking when my foot presses down? The truck is a 2004.5 with the nv5600 transmission. It has a 148000 miles on it and the clutch still works.
The foot lever pivot points? When you take off from a start? When the engine is running? When the engine is off? Does the pitch change with rpm? What else?
Otherwise there is a certain amount of metal rubbing when you press the foot peddle so just apply some forgetaboutit.
