D-C-Johnson's avatar
D-C-Johnson
Stabilization ??
In need of some input, Knowing that movement is going to happen I'm wanting to know if using additional screw jacks will help with rocking, I have my TT level, wheels chocked, and x-chocked, corners snug, but still have alot of side rocking.
  • I do it the same way as you with no problems. Either the tires are rolling or a jack is doing its job for whatever reason.
    With all that done it should be solid. The x-chocks must be tight.
    Have someone rock n roll inside while you do a visual on the exterior to see what is moving. I would think things are not tight enough unless one of the stabilizer jacks is having an issue.
