Huntindog
Aug 16, 2016Explorer
It depends on which power jacks you have.
The Lipperts (and at least one other knockoff) adjust automatically to uneven ground and maintain equal pressure between the two legs. This can be an advantage when boondocking as the legs will settle/sink into the ground. More so if it rains. This settling is usually not equal from one leg to another. The equal pressure of the Lipperts keeps this settling from racking the frame.
If you install the BAL locking mechanisim it will defeat the equal pressure feature.
If you camp on concrete or asphalt pads, then this is not a concern.
If you boondock, it is something to be aware of
I boondock a lot and always in unimproved sites. So I would rather keep the equal pressure feature.
If you choose to install it, and sometimes camp off the beaten path, you can simply not engage the locking struts.
44,056 PostsLatest Activity: Jan 12, 2020
