Reddog1
Apr 22, 2013Explorer II
I do not consider myself to be an expert on the stable Lift by any standards. I did in fact install my Stable lift by myself with no help, years ago. The only mistake/redo I had was the plates inside the TC, used to sandwich the existing TC overhang with the Stable Lift outside plate. Initially, I used 1/2" plywood. Overtime, the mounting bolts wicked water to the plywood. This caused the plywood to fail with the carriage bolts. I replaced the 1/2" plywood with 1/4" aluminum, and have had no issues since.
The plate inside the TC does not need to be one continuous piece, it can be several pieces.
I did/do not like the three toggle switches provided by Stable Lift. They work great, but you cannot see what is happening on the opposite side of the TC. I made a wire remote for my lift. I can raise my lift from either side of my TC, and also have a connector inside the TC to raise or lower the lift.
I do have as source for the gear box and motors. If I can be of help, let me know. I am sure you will appreciate your Stable Lift as much as I have mine. Mont, at Stable Lift, was very helpful with my install.
Wayne
Wayne
