Bedlam
Mar 05, 2014Moderator
StableLoads load up your existing spring capacity sooner to reduce squat. If squat is minimal after installing the TorkLift products, it may be enough or you may feel the need for additional support. If you know you will always be at a certain weight or greater where that weight still creates squat, go with a SuperSpring to get leveled. If it only happens when you are loaded heavy (maybe when you take along a lot of ammo for shooting, haul extra water through the desert or tow something), consider installing airbags so you have adjustability. In either case, let the main springs do most of the work.
My StableLoads are enough to help keep the TC from sagging the rear. When I hitch up the trailer, I use the bags to get level again.
