Freep's avatar
Freep
Stainless steel screws
I'd like to get a bunch of square drive stainless steel screws to have on hand for my Lance 992 camper. I would like enough variety to be able to replace any screw that I find needs to be replaced.
Do any of you have a good idea on size and length of screws I would need? My local hardware stores don't carry the square head screws so I'll have to order from amazon and I would like to avoid pulling random screws out to figure it out.
  • donn0128 wrote:
    Why square heads? Philips are quite common, and do the same job.
    Agree that Philips are common but I typically see square drive screws used in RVs.
  • Head configurations are kinda sorta personal preference and there are differences in how they install but I agree with donn0128, use Phillips. Having said that I also have a lance and most of what I have found are #8s ranging from about 1" to 1 1/2". I have some outside covers(i.e. Reefer) that are in the 2" range and some inside Louver covers that are in the 1/2" range. Not measuring, this is my best guess. I would suggest getting a supply between 1/2 and 2. Unless you want to replace them all just go to the local hardware store and get a handfull of each.
  • I would think that 3/4 would be the most common length, but i would carry an assortment of 1/2 3/4 and one inch, probable # 6 , #8, and #12. Also depending on what your running them into keep some locktite or a product to reduce galvanic corrosion.
    Happy Motoring.
  • Why square heads? Philips are quite common, and do the same job.
