mr__ed
May 20, 2013Explorer
Standard Transmission Fluid
I know most of you folks tow with automatics since standard trannies are becoming less available but since I have a standard tranny I was curious about what fluids you're using. The reason I ask is there is a general consensus on the various Dodge diesel forums that the factory-installed ATF+4 fluid is deficient in protective qualities and should be changed to something with a heavier viscosity.
The reason given why automatic transmission fluid is used is that ATF+4 fluid is more readily available to the manufacturer and less expensive. I haven't had any problems so far with this fluid and have already changed it once (using ATF+4). I believe the manufacturer knows what's right for this application but still wonder if there's any truth that a different fluid would be better/more protective, especially under high load conditions. What say you?
