This required a change in strategy so we found pleasure in spending our first dedicated outing with the new camper getting to know a bit more about her. First up was installing a couple of insect screens over the heater and fridge vents. I had found them on line for about half the price of a typical RV store and was itching to get them installed.
The fridge vents were a no brainer too. I read in the instructions for these appliances where they don't recommend screens like this, but after my many run-ins with mud daubers I opted for protection. With all the recent truck work done I have been crawling around underneath the F350 to verify that work was done to my satisfaction. In one of these forays I found the back side of one of my rear wheels was throwing gear oil. On closer inspection I found gear oil beginning to exit the front of the differential where the drive shaft enters. NOT GOOD! I was dreading the aspect of having to tear down my axles and install new seals. Enter the Ford Enthusiast's website, knowledge base for all things Ford. One of the folks suggested that I verify the axle vent tube was not blocked before jumping off the cliff.
He was right!!! The daubers had plugged up the vent causing the lube to push out past the seals. With the weight of the new camper on a long trip home from Boise it all made sense. Some brake lube to clean it all up and get it dry was all it took to get it into a state where I can watch it closer. So far no leakage. But I digress...
