scout266
Sep 24, 2014Explorer
Here is the excerpt from the manual (and I used my normal freshwater hose and fitted it to the city water port and put the other end in the water container)
Dry camping
You can gravity fill the fresh water system if you do not have access to city water;
however, allow extra time to fill the fresh water system if you are using this
method.
Follow the steps listed above; however, at step 3 put the other end of the non-toxic
drinking water hose into your container of fresh water, and turn ON the water
pump (instead of turning ON the water at the water source.) When the fresh water
tank is full, shut OFF the water pump and disconnect the non-toxic drinking water
hose.
Dry camping
method.
hose.
44,066 PostsLatest Activity: Mar 14, 2015
