SoundGuy wrote:
Ours friends were told that Starcraft had had this issue with quite a few trailers over this same time period. If this '14 Starcraft is still within it's 2 yr warranty there shouldn't be any reason for Starcraft nor the dealer to step up to the plate and repair the damage.
Yep.. same issue. As mentioned they changed the design so that now there is an overlap of the cap onto the diamond plate.
Issue now is that the dealer has tried to repair and actually made it worse. A child could have done better at slopping sealant over the crack. Plus, it remained outside at the dealer during the resent heavy rains we've had in this area so that now the flooring, walls, internal stud grid, furniture.. all are rotting and molding so badly as to make the trailer unusable.
