RVcircus
Jul 24, 2014Explorer II
joeyg wrote:
I just looked at your Pics, I see you have a KZ with the rear side.
I have a 2004 Frontier 2908, Soft corners as well.
So far, I peeled back the roof on the Awning side, cut out the Bad wood/Frame, reframed it, and put a new corner cut from plywood on.
Then, I reglued the corner roof back on and put it back together.
I was going to do the other side in a few weeks (after camping), but after seeing how bad that second corner is on yours I am a bit less gung-ho.
I wonder if this is a KZ design thing?
Good luck!
Have any pictures? I was hoping to do the same thing, but once I started digging deeper I decided to replace the whole roof. I was more damage than I expected.
My back wall is also going to need to be replaced along with a few studs, rafters, and 2 sheets on plywood on the floor.
It stinks that RV's are just left to rot away.
