RVcircus's avatar
RVcircus
Explorer II
Jul 21, 2014
Starting my roof repairs tonight (with updates & photos)
The trailer with picked up has soft corners and it's soft along the edge up to the fridge. I'm planning to peel the TPO membrane back as far as I can, replacing the sheathing, 4 rafters on the rear end, and regluing the TPO. I have all the materials on hand including dicor adhesove, lap sealant and eternabond.
I think I'm going to apply the eternabond tape along the edges on both sides & rear of the trailer just to reinforce where it goes over the side & under the trim. I'm not sure that this is necessary, but I don't hink having extra material at those bends will hurt. I'll also be applying lap sealant to the termination at the front and will cover it with eternabond just as an added layer of protection
Does anyone have any tips before I get started? I'm hoping to get the awning, trim, and vents removed tonight to I can start on the roof tomorrow.
Thanks
Mark
***UPDATE as of Feb 9th 2016***
Here's a current video of the trailer after the rebuild and a year and a half of use.
https://youtu.be/_CHmcgquP2g
  • I have used dicor to seal the edges of eternabond tape with success. Only place you need to do that is where the tape overlaps.
  • I think you might get a better Eternabond seal/bond by applying it directly and skip the Dicor or maybe use the Dicor to seal the edges of the Eternabond. Just a thought. Take some pics.
