Maybe I don't understand what you are saying, but I do not see anything that states the weight of your truck. What I read is the most it can weigh (GVWR) is 14000 pounds. The second decal repeats the tire data of the first, and says the combined weight that should never exceed (6229). Neither number says the existing weight of anything that I can see.
Actually I find the two decals a little confusing. Gross Vehicle Weight Rating (GVWR) is the maximum allowable weight of a fully loaded vehicle, including the weight of the vehicle, options, passengers, cargo, gas, oil, etc.. The first decal says it is 14000 pounds. The second decal says combined weight of occupants and cargo should not exceed 6229 pounds. The numbers suggest the truck weighs no more than 7770 pounds, but without knowing how it is equipped they still do not know. My bet is if you took it to the scales it would not weigh 7700 pounds.
I also see it states "with" tire size given and psi. If you have the original tires, would you look and see the load capacity on the sidewall is?
What am I missing?
