Reddog1
Oct 22, 2014Explorer II
I think I have some of this unraveled. I do not reconize the water heater. Does it have a make and model number on it?
I think I have the photos correct.
That is very common if the water is heated too hot. Usually, you can flip the lever a couple of times, which will allow the valve to re-seat. Best to wait for the water to cool a little before doing that. I would not put paper in the tray of the compartment, too easy to catch fire.
You have an arrow pointing at the drain valve in the bottom of the tank. It is the drain valve, and if your tank uses a anoid it will be attached to the plug.
My guess is that the pipe threads are not sealing correctly. Could be a cracked fitting. I see no choice but to remove the fitting, and put thread sealant on the threads. The drip is probably under normal pressure, and it turns into a spray as the pressure increases when the water is heated.
The fittings can be put on the tank before or after the tank is in place. It all depends on how the camper is constructed. I should point out, the fittings should only be hand tight, easy to over tighten with a pipe wrench.
The plumbing does not look right in the photo above. There is tubing going from the top (outlet) of the tank to the bottom (inlet) of the tank. Maybe I am just not focused, but that looks like a bypass. Maybe someone will chime in on this.
eveready1289 wrote:
Reddog1, I am attempting to post a picture of the water heater.
If it doesn't work, I have other developments that are puzzling.
eveready1289 wrote:
The pressure relief valve drips out the barrel, but not a lot.
It saturates a single sheet of roll towel I have placed on the tray of the compartment every day or so. Is it faulty or should I try and work the release lever a bit after I drain the tank.
eveready1289 wrote:
That brings me to the next question. What is the best way to completely drain the hot water tank?
Should I take the anode out and look at it for good measure? And won't that drain the tank mostly dry? I think this hot water situation is going to ride till the spring. Its dropping down to freezing every other night here.
eveready1289 wrote:
problem number 2. There is a pin hole leak in the tee fitting coming out of the top of the hot ware tank inside. Pic nbr 2 shows location with arrow. If you look close you can see a drop forming under the tee on the right side. It gets worse as the water heats up from a drop to a real fine spray. Any suggestions? I looks like a tight squeeze to get that tee out.
The cabinet is in the way. Are these pin leaks known to happen?
They don't assemble the fittings on the tank before they put it in the cavity do they?
44,068 PostsLatest Activity: Jun 01, 2026
