Sounds like pivot points simple wore. Many are riveted-no adjustment (another plus for the T/L steps they are bolted so can be adjusted).
There is an older post with this exact issue-cant find but had pictures of sagging stairs, treads at different angles.
There was discussion of re-drilling and replacing pivot points.
Though if I remember correctly he ended up with the T/L steps
edit: huh looking for something else and found thread I was thinking of
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27151303.cfmshows treads as described
