dodge_guy
May 17, 2020Explorer II
Gdetrailer wrote:GrandpaKip wrote:
The biggest problem for me is that I haven’t found any car stereos that have an A, AB, and B speaker switch. I do use this feature. I know I could add the switch elsewhere and may go that route when I have to replace that High Quality Jensen in the camper.
Good grief!!!
You let a small detail of a dirt simple external speaker switch totally defeat you into keeping those lousy "RV" stereos.
A $15 switch for heavens sake..
Looks like this..
Which IF you bought a good quality car stereo will have plenty of room leftover to mount the stereo AND the switch.
You can even buy more advanced speaker switches which add in more speaker connections, volume controls for each speaker giving you much more control than your hopeless "RV" stereo could give.
Your giving up a lot by locking yourself into RV trash stereos..
Advanced features like Streaming services like Pandora, BT streaming from your phone, tablet, PC, Sat radio, MP3/WMA through USB flash drives..
But, go ahead and stay with your 1980s RV "quality" stereo..
I was going to install something similar. But instead went with 4 push button switches that would do the same thing.
The cheaponly st car stereo is Bette than any RV stereo. I fact you could go so far as to install a double din touch screen and install a camera to monitor the outside if you wanted. Lots of options if you really put your mind to it.
