Thanks
I dont want to ,and I`m sure I cant talk you into something you dont want to do yourslf, but the wiring is this simple
Buy a kyocera kd 140sx-ufbs panel thats 140 watts and has a junction box from somewhere like northern arizona wind and sun , theres a + and a - terminal inside the j box hook up some 2 conductor (like romex) outdoor wire to the terminals , put a plug end from lance on the other end , plug it into the socket on the ref. vent , find the other end of the lance pre- wire , probably at your battery area ,hook one wire to + and one to- on the charge controller
like this one marked solar/ battery , and run two wires + and - to the battery . Keep the positive and the negitive wires all the way the same and put a automotive type thermal auto reset fuse 10 amp on the + wire in between to charge controller and the battery,
Not for everybody I`m sure , but maybe you thought it was more involved than that
The guys at northern arizona wind and sun are very helpfull and can sell you what you need ,panel - wire - controller... Ive found there prices to be good when Ive bought from them
Good luck
