tomman58
Apr 22, 2020Explorer
sticky slides
The last couple of Jaycos have had slides that really seem to stay stuck to the trailer body for a longer time then they should, IMO. I mean when I open or close the slides after they have sat for a...
carringb wrote:WD 40 is not an oil. It uses a petroleum based solvent as a carrier for the lubricant, which is basically wax. The carrier flashes off (dries) very quickly, leaving a very thin film of wax. This is how it displaces water and protects metal from rusting. In fact, that is how it got it's name. The chemists working on it tried many different conbinations. WD 40 = Water displacement formula #40.
303 or even silicone spray. WD-40 and many other oils are likely to damage it.
