plasticmaster's avatar
Aug 28, 2022
Stiffer bars for Blue Ox hitch?
Just got a new truck and noticed that when I hitched my travel trailer to it, the rear end squats a little as compared to the front of the truck. I have the Blue Ox hitch and typically I would adjust the chain length to give it more tension. However, doing so would cause the bar to hit the battery tray on the tongue of the camper in turns. Could I use stiffer load bars to provide the correct leveling which would allow the chains to be longer?
  • Just an fyi. The head on the Blue Ox is not adjustable like the Equalizer hitch. Tension and weight transfer is determined by the chain.
  • Tilt the hitch hear rearward back towards the trailer a bit more before you hook up. This will give you more tension on the WD bars with the same chain link as before and allow the bar to clear the battery tray.
    Barney
  • eHoefler wrote:
    You need to have the head adjusted for the new truck, either up or down, and the tilt. The hitch is set up for the truck, not so much the trailer.
    The receiver of the new truck sits 1 inch lower than the old truck. Therefore, I raised the ball portion of the blue ox hitch 1 inch (the part that's made for raising and lowering held with the 2 large bolts). I did this before ever hitching camper to the new truck.
  • You need to have the head adjusted for the new truck, either up or down, and the tilt. The hitch is set up for the truck, not so much the trailer.
