agwill
May 19, 2013Explorer
Are you sure about the colors? Yellow and green should be left and right turn signals. Brown should be running lights and white ground. Blue is for your brakes. The other two colors are for batteries usually the center pin of connector and back up lights on trailer. The first test should always be check your ground. Hope this helps.
44,071 PostsLatest Activity: Sep 17, 2026
