Dtaylor
May 19, 2013Explorer
This has been many years ago, but had an issue exactly as you describe. It turned out to be the turn signal switch in the truck. Everything would work perfect until the trailer was connected and then nothing. Not sure if that is your issue but might be another place to look. I would also look for and check any ground points on the trailer
44,071 PostsLatest Activity: Sep 17, 2026
