SprinklerMan
May 19, 2013Explorer
take a 12 v battery , hook a ground wire up to the frame , go to a side marker light and take the positive wire and run a jumper to the hot on the side marker . All the running lights should be on when you do this . Now go to the junction box and search for a hot wire , that will be your feed for the running lights . Odds are there is a grounded out wire somewhere on the line . Now if it all works straight off a battery , put a 5 amp fusable link in line on the hot and see if it blows . This will help narrow down the problem .
44,071 PostsLatest Activity: Sep 17, 2026
