Repoman1
May 20, 2013Explorer
Rubber Ducky1 wrote:
Agwill has it right. The color code is as follows:
White: Ground
Yellow: Left turn
Green: Right turn
Brown: Taillights (& running lights)
OP you said you used GREEN wire to get your running lights on. That has me confused.
The diagram on the inside of the plug shows green as the running lights. And when I hook the green straight to the 12 volt battery all of the running lights come on.
Brown is a turn signal for this trailer and yellow is nothing. When I opened up the junction box the yellow was caped off from the factory with one of their close off ends.
Im going to go to a local dealer tomorrow that sold me the plug. But also its strange that when I put the green to a power source all of the running lights come on like they should. How would you explain that?
44,071 PostsLatest Activity: Sep 17, 2026
