Repoman1
May 20, 2013Explorer
handye9 wrote:
I've had same problem (flasher, brake, tail, and turn signal lights work / running lights do not) with three different truck and trailer combinations. The trucks were 03 Toyota Tundra, 06 Nissan Titan, and 08 Ford F250. All of them, had a blown fuse in the truck.
OP - Check the owners manual for your truck. In addition to your interior fuse box, you probably have another one, under the hood. There are seperate fuses for each of the trailer lighting systems. One of them operates running lights, only.
I've checked all the fuses the whole thing is I have power at the plug in female connector at the back of the truck but there's no power once I plug it in. so I'm fixing to head to the dealership
44,071 PostsLatest Activity: Sep 17, 2026
