leftybj
May 20, 2013Explorer
It is hard to troubleshoot a problem without collecting the data myself but I will take a stab at it.
My guess would be that you have a bad connection on the truck side. If you check for 12V with a meter it will appear to be OK as the meter does not need much current to measure voltage. Maybe only microamps, depending upon the meter. The running lights require considerably more current to operate and the bad connection will not let this happen. It is like a garden hose that is pinched...you have line pressure (voltage) but there is no flow (current).
Retired Electrical Engineer
