- snowcrustracerExplorerWe can get a lot of snow where I live so I store the camper with the top down. I don't think the lifting panels on the Four Wheel Camper would hold up well with a large snow load and high winds. We store the camper with the jacks down supported on saw horses and cover it with a old satellite dish cover. The mice can not get up the jack legs so no worries about critters chewing up cushions and Webalon
- OldtymeflyrExplorerWe purchased our outfitter in 2009. I asked about it at that time and the answer was that it did not matter one way or the other. It seemed to be that If the camper was put away wet, as in a trip that it should be aired out.
We have kept the top up or down (in all seasons) as we need it and its holding up well.
Rick - sharkmanExplorerAlways stored our popup top down, wouldn't take the chance of anything putting a hole in the canvas.
- silversandExplorer
M Kirsch wrote:
HOWEVER, I would not consider leaving the top up if the camper was outside, even with a cover. Critters are more likely to chew through canvas than filon or aluminum.
....we have just about every vicious animal you can imagine in our big forest (square miles of it). That including fisher cats patrolling nightly (always after our neighbor's chickens!), bobcats, porcupines, red and gray squirrels, mice, plenty of raccoons (they can open our garage door (the small door with lever entry handle, not the 12 foot wide pull-up), and numerous other medium sized and large tooth carnivores (like plenty of black bears), and over 9 years of parking the camper rig in the forest with roof up for 6 months, not one has ever chewed through our Weblon soft wall (but your mileage may vary, depending where you live !).
On edit:....just thinking aloud, we had a mountain lion around here in 2010 that attacked a horse at a local ranch (while the ranch owner was fairly close by!)...ya, we do have mountain lion in the Northeast. They are VERY rare, however (probably escaped from illegal breeders facilities). It was never apprehended. - jfkmkExplorer IIWaterproof cover? As in, doesn't breathe? Not a good idea for any camper, as it traps moisture
- rfgaugushExplorer
sstan wrote:
I asked Outfiiter about this when I took delivery. They recommended storing with the top up to reduce the pressure on the torsion bar springs. We had our Calmark cover made to fit the camer with the top up.
When did you purchase your Outfitter? I wasn't told that when I purchased mine in 2015. - d3500ramExplorer IIIWhen I had my 2 previous pop-ups, I stored it without any cover of any type with the top down- never had any issues However, I always made sure that there was absolutely NO moisture or water when dropping the top down.
If I had to bring the top down when leaving a campsite for travel in inclement weather, I always made sure to run it up at home when appropriate to let it dry and air out... being so very dry humidity in my region, the airing it out was easy - mkirschNomad III asked this about 6 years ago and the universal response was top down. That advice has not led me astray yet. Every spring when I pop the top for the first trip of the year, the canvas is still there.
Now, my camper does not have any springs on the lift mechanism, so that may be a consideration. HOWEVER, I would not consider leaving the top up if the camper was outside, even with a cover. Critters are more likely to chew through canvas than filon or aluminum. - sstanExplorerI asked Outfiiter about this when I took delivery. They recommended storing with the top up to reduce the pressure on the torsion bar springs. We had our Calmark cover made to fit the camer with the top up.
- Steve_in_29ExplorerSince you keep it covered, top up with vent/window cracked will keep interior temps down and avoid issues with heat build up.
44,068 PostsLatest Activity: Jun 21, 2026
