- silversandExplorer....during summer, I park the truck camper (Outfitter Caribou 8) rig partially under a tree canopy (hardwood maple and white ash and beach, giving shade to the softwalls but for only ~2.5 hours a day; so, I have very little sun hitting the softwalls during summer at our camper parking area) with the roof up all the time (and if expecting rain, I lower it down). So, from end of April till about 2 days ago (it went into heated storage for winter), or nearly 6 months, the roof was in the up position (except when raining).
Over winter in the heated storage facility, I did, one year, store the camper with the roof up the entire 6 month-ish winter. I stopped storing over winter with roof up because cleaning the Weblon softwalls the following spring was getting very old-- and this was the one and only time (it was filthy!).
Some pop-up truck camper manufacturers suggest keeping the roof up when not in use for extended periods....this may be because the softwall pleats endure a lot of stress when folded (I know the pleats on our Weblon softwall appear to have more wear than the unpleated softwall, for sure). I have to add, that our Weblon softwall is very, very, VERY stiff, and does not move but for a fraction of an inch, even under gale-force winds.
What you do would be based on your camper manufacturer's recommendations, and the outdoor environmental conditions. - DutchmenSportExplorerIf the cover is loose, and you are parked outside, the wind will rub the finish. You'll regret that when you remove the cover.
If you store it outside, tighten that cover. With that said, why raise the camper? Do you see folks storing their pop-ups over the winter opened up? Does it hurt them?
If your TC is inside, under roof, it probably won't matter. But if outside ... I think you should button it up tight! Tie it down solid.
44,056 PostsLatest Activity: Jan 12, 2020
