donn0128
Oct 13, 2016Explorer II
You should do a complete winteriae. Blow out the water lines using LOW pressure air. Add antifreeze to the toilet and "P" traps. If you have a washer or ice maker, then you need to push anti freeze thru everything to be safe. If you have enecteicity in there, add an electric dehumidifier. Close everything up tight. Be sure to add a bunchmof mouse traps to srop unwanted guests. Either take the batteries out and store them someplace warn with a charger on then, or leave the trailer plugged in. Check the batteries monthly and add water as necessary.
