mikakuja
Oct 13, 2016Explorer
Agreed, if the temp is going to be below freezing you have to winterize.
My opinion is, use the pink antifreeze. Using the air method does not guarantee that you will get all of the water out of the lines.
My method. Fresh drained, hot water tank drained and bypass valves off. Starting from the closest tap to the furthest including the outside shower and low point drains etc, run each tap until pink flows. If I have any left I pour a bit down each p-trap. there will be enough in the black and grey tanks to reach the drains. Fresh tank does not need any winterizing.
I don't leave my windows open but with the maxx air covers I leave the vents open slightly. I also have a couple dri z air pots in the trailer.
As far as rodent traps, I leave a couple traps on the edges of the floor near the furnace vents. In all the years we have had trailers I have only had mice once and the vents were their preferred place to hide. Never did figure out how they got in though.
