solar07
Oct 13, 2016Explorer
mikakuja wrote:
My method. Fresh drained, hot water tank drained and bypass valves off. Starting from the closest tap to the furthest including the outside shower and low point drains etc, run each tap until pink flows. If I have any left I pour a bit down each p-trap. there will be enough in the black and grey tanks to reach the drains. Fresh tank does not need any winterizing.
Could you explain "fresh drained"? Also, what is a P-Trap? So none of the antifreeze goes into the fresh water tank....
Thanks!
