todde278's avatar
todde278
Stove replacement for outdoor kitchen
I have a 2015 coleman trailer with an outdoor kitchen. The 2 burner stove that comes with it is terrible. The slighest puff of wind blows the flames away. I have a 2 burner camp stove that runs on propane bottles and has the small flames and seems to cook much faster. I would like to adapt this in place of my current stove.
I am sure i can fabricate something for the stove to slide in and out of the kitchen with a little work. My question is will the camp stove work from the propane line in my camper and is there an adapter line that will plug into the quick disconnect on the camper as well as the camp stove? The camp stove has a curved brass line that threads into the stove and the small propane cylinder goes on the other end. Similar to this: http://images.brinkmann.net/docs/pdf/842-A100-S.pdf
Thanks
Todd
  • You will need an adapter or modification to the stove as you are coming from low pressure in the trailer to high pressure for the stove, unless it can be modifies and a quick search did find anything.
    Were it me I would go for a drop in cook top and shields for the side.
    cook top
