As evidenced above you can't just go by wire color as mine is the opposite. My Jayco from the factory is wired Black positive and white negative.
If you have no power after replacing the fuses that blew in the trailer you possibly have a second fuse or circuit breaker out on the positive wire on the tongue that's blown.
At the battery take a moment and just look at the wires and where they go. The negative(s) is going to go to the frame and probably fairly close to the battery. The positive(s) will usually have a fuse or a small box (circuit breaker) inline near the battery.
A circuit breaker is typically (not always) a small box with two bolts and nuts with a wire under each nut. Using your meter set to 20V DC check from each post on the circuit breaker or each window on any fuses back to the negative terminal on the battery. It has to be the post that the negative wire from the trailer is connected to.
You should get the same voltage measuring from each post or window back to the negative post on the battery. If you get 12v on one post or window and zero or a significantly smaller reading on the other post or window you have a bad circuit breaker or blown fuse.
![](https://i.imgur.com/xKUJqOj.jpg?1)
![](https://i.imgur.com/D42LGth.jpg?1)
