JBarca
Nov 26, 2017Nomad II
TurnThePage wrote:
My gen weights about 120 lbs, this tray weighs around 60-65 lbs. My whole trailer weighs around 6000 lbs and has a 6000 lb gvwr. I'm not sure what the tongue currently weighs but the trailer is well balanced and tows true. It's probably in the 750 lb neighborhood. It seems doable, but...
I looked up one of those trays. Like this at Camping world http://www.campingworld.com/shopping/item/trailer-tray-a-frame-cargo-carrier/70918
What size generator do you have? 120# is no small generator. Holy cow... A Honda Eu3000 which is beastly, only weighs 75#. My Honda EU2000 I lift in and out of the truck bed but even that is about all I would want to lift in and out.
Since it is your genny and it weighs 120# I'm assuming you have figured out how to lift it that high onto that tray up above the top of the LP tanks.
If you can get past that, with the light weight of steel they make in TT A frames now a days, I would be concerned about WD forces with the added weight on a light weight camper of 6,000# GVWR. Adding 185# of genny and rack to hold it on the A frame could mean you need heavier WD bars. Some of these smaller campers have a hard time with heavy rated WD bars even if your loaded TW is less then the WD bar.
Before you mount, I would recommend you scale the loaded tongue weight where you are now, add the 185# to it and this will tell you the WD bar needed. You can only buy certain sizes. This may put you into a 1,200# WD bar. Then call the TT manufacture and make sure that your trailer frame will allow WD hitch bars that large. Going up and over high up RR crossings and other up's and overs along with compound angle turns can create very high WD forces on the inside turn WD bar & A frame rail. Those high force can result in twisting the A frame rail and or the camper frame header to the point of failure over time.
Hope this helps
John
