Sea_scape
Jun 19, 2013Explorer
If I read your first post correctly, you measured 11 volts from the break switch to ground. This is without load because you had disconnected the blue wire to the brakes. This is an unchanged battery, and the voltage will drop more when the brakes are connected.
Charge the battery, or plug the trailer in to see what happens. Measure the voltage as you did, but with brakes connected and you will see actual voltage.
44,071 PostsLatest Activity: Aug 16, 2026
