69_Avion
Jun 19, 2013Explorer
I would try charging the battery and then see what happens. The output of the switch goes right to the brake wire which is usually blue in a standard wiring diagram. As far as putting a fuse in the break away switch line, if I was going to do any type of current safety it would be an automatic circuit braker. The last thing you want to have happen is your trailer not stopping if it becomes disconnected from the TV.
44,071 PostsLatest Activity: Aug 16, 2026
