woodtrucker
Jun 24, 2013Explorer
I just jumpered a wire over from positive terminal to brake wire in camper to see if I could get brakes to actuate by touching it to the positive battery terminal and I get a weak clicking sound but then when I plug in TV and push override down all the way I get a good hum on brakes. I left the camper plugged in over night and the battery was charging at about 13.6 volts. When I checked the switch this morning (before this last test) I measured voltage accross battery with breakaway switch pin in place and got 12.6 volts and with it pulled I got 12.4 volts so it is drawing on the battery so is it safe to assume that it's working even though I really don't hear a hum?
44,071 PostsLatest Activity: Aug 16, 2026
