akronharry
Jun 24, 2014Explorer
Subflooring Idea
I have to replace a section of flooring in my TT. The flooring inserts into a C channel along the perimeter of the trailer. The flooring is 3/4 inch thick and about one inch at the edges of the plywood are shaved down to about a 1/2 inch to fit into the C channels.
My idea is: Lay 1/2 inch plywood around the area so that it can easily slip into the C channel. This would consist of three cut pieces. Then use 1/4 inch plywood with lots of glue and place over the 1/2 inch plywood and cut it so the seams from the original pieces are covered over.
WOUld structual integrity be compromised in doing this. I don't think so, but want to make sure.
