akronharry's avatar
akronharry
Subflooring Idea
I have to replace a section of flooring in my TT. The flooring inserts into a C channel along the perimeter of the trailer. The flooring is 3/4 inch thick and about one inch at the edges of the plywood are shaved down to about a 1/2 inch to fit into the C channels.
My idea is: Lay 1/2 inch plywood around the area so that it can easily slip into the C channel. This would consist of three cut pieces. Then use 1/4 inch plywood with lots of glue and place over the 1/2 inch plywood and cut it so the seams from the original pieces are covered over.
WOUld structual integrity be compromised in doing this. I don't think so, but want to make sure.
  • Was the original subfloor one piece or three cut pieces? Any time you create a joint, you'll diminish the integrity, somewhat. The question should be, "will I compromise the flooring beyond it's function?". If you can place an additional piece under the joints it will add strength. If the adhesive you use to attach the 1/4" overlay bonds both pieces and the adhesive is stronger than the wood plys (it will be), then the total strength will be similar to the original. Remember to observe direction of plies when using plywood as a subfloor.
  • Gdetrailer wrote:
    A router (for WOOD WORKING not internet) with the proper bit, set to the proper depth would be my first choice. Even a cheapo router and bits from Harbor Freight shouldn't set you back much at all.
    Your suggestion could work but would sacrifice some strength and depend on having a good glue bond..
    Plywood is made using alternating layers of wood plus specific glues for the laminating process and is put under many tons per square inch of pressure while the glue sets.. You will never be able to match that using your idea.
    Thanks!
  • A router (for WOOD WORKING not internet) with the proper bit, set to the proper depth would be my first choice. Even a cheapo router and bits from Harbor Freight shouldn't set you back much at all.
