softballjunky's avatar
Jan 15, 2020
Suburban furnace issue
Hi all, I tried searching for my particular issue but couldn't see a post exactly like mine. 12 year old suburban furnace in travel trailer that will turn on and blow hot for about 5 minutes and then shut off before getting to set temp. I cannot get it to turn back on for a while, then after about 30 minutes it will run for a few minutes then shut off again. Where should I start? Any ideas would be great. Thanks in advance.
  • Wasps love building nests in the intake and exhaust ducts of these furnaces. I once removed a furnace and dumped a whole coffee can full of wasps nests out of it. Try looking down your intake and despicably the exhaust duct for nests and clean them out if you see any. It might be enough. If not you may have to remove the furnace to clean it.
  • Probably heat related. BryantRV has service manuals online for download. Just scroll down to the furnace section
    Link
  • garyemunson wrote:
    I'd suspect the high temp limit switch is failing and opening at too low a temperature.
    2X that, or you may have an obstruction in a heat duct or a closed register.
  • I'd suspect the high temp limit switch is failing and opening at too low a temperature.
