hondapro's avatar
hondapro
Suburban oven problem
During our last trip our oven developed a issue.The pilot light will light and so will the burner, but about 1 second after the burner lights there is a little poof sound and a orange flame appears back near the pilot light.The flame is about the size of a candle flame.
The rest of the burner works fine and has a blue flame,the oven seems to work ok.
I an just concerned because I never noticed it before.
Thanks for the help.
  • The pilot tube has sprung a leak. First, do not use it until you get it fixed.
    Start by using a small wrench the check and be sure the orofice is screwed in tight. Maybe its just come loose. If its all tight, then you probsbly need a pro to inspect and repair it.
