StirCrazy
Jan 01, 2021Moderator
Old-Biscuit wrote:StirCrazy wrote:Old-Biscuit wrote:capacitor wrote:
Is your model SW6 d, if so it is propane only. SW6 de is both gas and electric.
Picture OP posted show the oval cover for electric element......only used on Combo units
Sidewall info states 6 gal
So OP could use Electric for heat IF AC Power is available
but the electric switch is missing, so it has me wondering which unit it is also.
most likly it is something gumming up the actual valve not letting it close fully, if you not used to working with this kind of thing just replace the gas valve with a new one.
Steve
Electric On/Off switch to left of Oval cover for element (they do not install that w/o it being electric)
OP may even have a 'DEL' model that uses DC for control of Electric & Gas via a Relay
OP must be out camping.......hopefully OP will report back with answers/resolution IE: Gas Valve fixed
weird, I have the same one and the local eletric switch is in the top left corner above the propain line where the white sticker is... guess that depends on the installer?
Steve
