canoe_on_top
Apr 04, 2021Explorer
Arctic Fox/Nash definitely top choices. Get the factory storm windows.As mentioned, the big problem would be either leaving the heat on all winter or re-winterizing after every trip. If you don't have shore power you're going to need significant battery capacity to get you through the night and you'll have to run the generator quite a bit during the day. At least two 6 volt GC batteries. With my previous Nash and current Arctic Fox, I've seen 5,6 below with no problem. Could, probably handle -10. As you know, it, occasionally, gets colder than that in Denver so, plan accordingly. If your trips coincide with extreme temps, 10-15 below, you might have to not use the onboard water system and use portable water containers. Not conducive to showering.
