afidel
Apr 05, 2021Explorer II
So here in NE Ohio I went through 20-30 pounds of propane a week, that was with an electric fireplace burning pretty much 24x7 at 1200-1500W, thermostat set at 40 outside of work hours, and all windows covered with Reflectix. If you needed to keep it above 40 without the electric figure closer to 50-60 pounds per week (based on BTU value), and on top of that you'd need enough battery to run the blower that much. Basically you'd be looking at ~28 gallons @~$3/gallon per 2 week use just to keep it from freezing even if you could get a big enough set of tanks and a solar system big enough to keep up with the blower load.
