azrving
Apr 16, 2019Explorer
Just thinking that if you run a mobile home and an rv it's common to run 100 amps. Doesn't mean you must. If you were running two AC units and two microwaves you'd be hitting 60 plus amps probably. Doesn't mean you will be doing that but...
I have a 30 amp FW and micro and ac pull 30 amps together. No matter what you want the wire sized and breaker sized so the wire doesn't become the fuse.
