Stoic_J
Apr 19, 2019Explorer
myredracer wrote:So, my thought was to lay out the wire, then slide the conduit down from the house panel to the RV panel. I'd cleanly cement each section as I went along. Perhaps I'm missing something but seems to me like that'd work. If you're working with an existing conduit run then, yeah, you gotta fish it through, but I don't see why my idea wouldn't work. If it turns out I'm missing something, maybe I could go with 45's (these aren't hard 90's they're sweeps, but yes the sweeps aren't very long) and use the other suggestions.
I bet the cut price to get another 240' will be more! That could be a tough pull at 240'. You could always install a plastic pull box 1/2 way if needed. You may need a come-along or winch tied to a tree or truck. I always used to use the rule of thumb that the max. code allowable in 1" conduit is 100 amp wire at 120/240 volts and that was before THHN was around which is smaller dia. and a bit slippier. As I said before, it you can leave 90 degree bends off at each end it will help a lot. A 1" PVC bend is a bit of a tight radius for 3 x #4 wires and will make it harder to pull.
Have fun!!
