rhagfo
Apr 19, 2019Explorer III
azrving wrote:
If you don't need a permit wire as you like. If you are supposed to get a permit wire it as required in case you get popped. At least that's how I cheat. I cheat but I don't leave myself open to double the cost. Risk reward I suppose
Very Bad advice, save a couple $$ burn something down! Two things I don't cheat on Electric and Gas, all done to code!
pianotuna wrote:
#4 copper wire in conduit. Use four wires.
Very Good advice!
To the OP, you state you are coming directly off the power pole, is this before or after the meter??
If before the meter you will also require a meter base (This would also be best as you would get a separate bill).
If post meter, and you are truly hooking up to her 200 amp panel, you should be sure that she can share that much amperage, and how are you planning to share the bill?
