Stoic_J
Jun 14, 2019Explorer
SoundGuy wrote:
Your post is confusing as it infers 50 amp RV service is just 50 amps when in fact it's 50 amps across each of 2 legs, for a total potential draw of 100 amps. You really have a need to draw that much from your sister's 200 amp service? :h
I have a 30-amp trailer, and I NEED enough for that. I would like to have an additional 30-amp trailer that STAYS on the property.
The panel I got has a 50 RV outlet, a 30 RV outlet, and a standard receptacle on a 20-amp breaker. I would just leave the 20-amp off, and run 30-amps max on each of the two trailers. If running two A/C's at once was a problem I would just have to alternate.
