- JIMNLINExplorer III
Busdriver wrote:
Have them on my truck & trailer, never a problem in 4/years
I have a pair of Sumo on the wifes 1500 chevy rear suspension just for pulling my 10k car hauler with a 7440 lb blue tractor/implements. No issues in over 7 years.
I got the idea from one of my haulers forums I frequent.
Scale house DOT doesn't like a sagging truck and for years we used air bags to level the load. Then some haulers started using sulastic springs like the Sumo/Timbrens instead which acts the same as a over load spring. In this type of work truck owners may run a 100k miles a year or more. Some report their Timbrens or Sumo's have several hundred thousand miles of service on their truck or trailers.
Excellent vid quality .
I would prefer a flat surface at the top end instead of a 2" wide U channel flange. - Grit_dogTrailblazerGlad to hear you’re happy with your purchase, but Trying to wrap my head around something with a stiff suspension, how making it stiffer makes it smoother.
Have used Timbrens and other similar suspension aids in the past, for trucks hauling more than they should, not less. - Grit_dogTrailblazer
afidel wrote:
Tyler0215 wrote:
Sounds like $500 wasted to me. The hard jounce when the Sumos meet the frame will be hard on the trailer frame.
Sumo springs on a truck sound equally bad.
Sumo springs or similar can be good on a 1 ton or 4500 pickup to provide some unloaded cushioning that the heavy spring pack lacks.
That is exactly opposite of what they do, but…. - RbertalottoExplorer
As we sometimes say in the world of engineering...."PFM"! - BusdriverExplorer IIHave them on my truck & trailer, never a problem in 4/years
- RbertalottoExplorerTwo hundred mile trip yesterday ....and in a word..."FANTASTIC". Hard to believe how four urethane cylinders could improve the ride of the Tow Vehicle. No more jerky jerky when going over bridge expansions. No more bucking on washboard roads. This trailer is a toy hauler. Designer to carry a 1000 pound toy. When unloaded the suspension is very stiff. These Sumo springs smooth the suspension right out. I bought them from Amazon so I could return them if they did not work as advertised. But I'm starting to believe they might be the best $500 I've spent bon the trailer.
All the internet engineers on this thread might be disappointed that they actually work. Sorry about that.
As far as the post about them not contracting the chassis. Watch the video again. That picture was with the chassis jacked up and the whole spring system hanging. When you install them. You add spacers to maintain about 1/2" of compression.
And as far as the comment about the Sumo springs bending or otherwise damaging the frame rails..... Totally ridiculous..... And I AM an engineer!:) - afidelExplorer II
Sumo springs or similar can be good on a 1 ton or 4500 pickup to provide some unloaded cushioning that the heavy spring pack lacks. - valhalla360Navigator
I'm not sure if I agree with this application but there isn't a "hard jounce". They are progressive, which means, the initial resistance is minimal and it ramps up as compression increases.
The one item I question is leaving a big air gap.
- With a truck where you normally run empty but occasionally put it under heavy load with the RV attached, it makes sense.
- With the trailer, presumably, there will be minimal variation in loading. - GdetrailerExplorer IIIGlad I am not the only one that is a bit skeptical about those pucks..
What was the reason why you fell you needed them?
The idea of having a suspension is to have some movement or compliance.
Those pucks take away compliance, potentially making the trailer ride stiffer.
Take away that compliance and it puts strain in places that shouldn't have strain. The frames are not reinforced where that puck touches and for any boxed frame there should be concern over how much up pressure is is targeted in one small part of the frame.. Without reinforcement to spread the load you can easily flatten the frame..
Its your RV to do with as you wish, myself, I think it is more of a non issue that someone made a product for. - Tyler0215ExplorerSounds like $500 wasted to me. The hard jounce when the Sumos meet the frame will be hard on the trailer frame.
44,070 PostsLatest Activity: Aug 07, 2026
