4x4ord
Jul 06, 2022Explorer III
wrogers wrote:
The backup assist harness and sensor came with my 2021 F450. I installed it to my 5th wheel but did not use it. It has to be calibrated to your particular trailer and is done by going to an open area and driving and turning with it when it says to do so. The issue I found is locating an area that is open enough to be able go straight, turn and so on when it says to do so without parking stops or other vehicles in the way.
I have actually removed it and just back up the old fashioned way and don't have any problems. But then again I used to drive a tractor trailer and have had plenty of practice.
Perhaps if I can locate an area suitable for calibration I may try it just to see how it is. I think it would take a bit of getting used to using a small knob to steer rather than the steering wheel.
Calibrating doesn’t require much space …. a quiet street provides ample room. Calibrating it takes about 10 seconds.
