If your going to install a super hitch does it matter if the truck has a factory hitch on it or not? Debating ordering tow package or leaving it off. JJ
If you're talking about a Ram truck, the factory hitch is actually part of a frame crossmember that can't be removed without lifting the bed. I wanted to actually remove the factory hitch but once I discovered that, I left it in place and installed the Superhitch below the factory one.
